Crab steamer
LWH
Member Posts: 1
Any tips on installing a steam boiler to steam crabs...hot water for make up from water heater or coil, piping diagrams etc
Constant loss steamer
There are a few postings here on that subject, so do a search.
The problem to be overcome is the constant addition of fresh waste to the boiler which can introduce too much oxygen into the boiler hastening it's demise.--NBC0 -
Here's one we did
in the back of a truck, no less............
http://www.heatinghelp.com/forum-thread/138701/In-the-Land-of-Pleasant-LivingAll Steamed Up, Inc.
Consulting0 -
Feed water
Feed it through a small water heater, set at the highest temperature, and use a microbubble reabsorber in the feed line. That will take care of the air and the heater will give the sediment a place to settle, other than inside the boiler. Adds years to the boiler's life.Retired and loving it.0 -
WaterHeater, microbubble reabsorber?
If this works to prevent the introduction of co2 into the system, why isn't it used with residential steam for make-up water?Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Steam
Why, indeed.
The reason is...no reason.
The REAL reason is that a residential boiler should not be using a lot of fresh water. And if water is added for maintenance, it should be boiled immediately. Whatever sediment accumulates over the years can be cleaned out.
In this crab steamer, there is so much fresh water being used daily, that you there is no way to maintain it often enough to prevent a problem.0 -
You can use hot water for make-up water
But don't run it through an automatic water feeder.
(Actually, consult your local code. It might not allow this.)Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
