Flat plate install
jelly
Member Posts: 3
Pumps on return or supply sides on a flat plate install?
Where's the expansion tank?
Pump away from the tank and all should be well.0 -
Electricity
In addition to "pumping away", I would suggest using zone valves and an ECM circ like the Grundfos Alpha. Your system will use much less electrical energy.
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
