Odd combined single pipe in a 2 pipe system
Landy
Member Posts: 7
There is one steam feed in my basement that has a T with a return to my wet return below the steam feed to a radiator. Is this common? Is this OK? I have not been able to identify a specific radiator it feeds, so could it have a different purpose?
Homeowner with new (12/2012) Dunkirk PSB-7D steam system with 726 sq.ft. EDR in a home built in 1925.
Steam
Could just be a riser drip to compensate for the inability to properly pitch the run out. Shouldn't be an issue.0 -
Maybe
there is an air vent up there, which was hidden when the ceiling was installed?All Steamed Up, Inc.
Consulting0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
