Burnham V14 tankless heater cover leak
longbeach
Member Posts: 2
in Oil Heating
Hi, I have a Burnham V14 that was installed in '89. It's been working fine but I developed a leak at the tankless heater cover. The gasket is shot and the cover is pretty well rusted also. Is the cover a separate piece or does the cover and the coil come as a whole unit? I have the original literature and it shows a cover plate but lists it as a blank cover plate. It also shows a tankless heater with a cover plate attached. I can see on the old one where the fittings thread into the cover plate, but how does the coil attach to the back side? I would just like to find out what I am getting into before I tackle this job myself. Thanks, Wayne
One piece
The tankless coil and cover plate are one piece. If the plate is in real bad shape you might be better off replacing the whole thing. You would be better off to get a pro to do it those bolts are easy to break off in the boiler if rusted bad.Aaron Hamilton Heating
ahheating@ yahoo.com
(207)229-77170 -
OK, thanks Aaron. I'm pretty much used to dealing with rusty, worn out bolts. I won't go into why. But, if it's a straight swap out I feel pretty confident. I'm still on the fence about whether to call a pro though. I deal with a lot of machinery, just not boilers and furnaces. Thanks for the info and the speedy reply.0 -
Old rusty bolts:
If you choose to change it yourself, buy a complete new coil. It comes with the plate and is one unit. Hopefully, it will come with a black rubber gasket instead of a red one. They become as hard as a tar road and will leak in time.
If you do decide to change it. get a can of Kroil. Spray the bolts every day for some period of time and try to work them loose before you do the swap. I find that nothing I have ever used for bolt rust removing approaches Kroil and I have tried everything made. If you don't have any, or don't know where to get it, you can but it direct from . It is for professional use only and not sold in retail stores.
I have changed faucets where no part of the install was greased. Years later, I needed to change the faucet and a basin wrench under the sink would not budge a nut. I spray the whole mess with Kroil and come back the next day. The whole thing comes apart.
Brute Strength breaks things. Finesse gets them apart.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
