To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
rheem warm air furnace
Paul SPaul S Member Posts: 1,202
I have another problem with burners not lighting fully across...brand new them two stage furnace...only one burner lights...the one closest to the spark igniter...they light full across when I blow the gas around when its trying to light....I checked incoming gas pressure I'm getting 6.8" wc....on the outlet I'm getting .40"wc reading on both high and low fire...cannot adjust both high and low regulator on gas valve....I screw the set screw all the way down and up on both high and low regulator with no change in pressure and visible firing rate....faulty gas valve???
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
[email protected]
ASMHVACNYC.COM
  • Paul SPaul S Member Posts: 1,202
    model and serial
    Rheem......model # rgpe-10ebrmr.....serial#gz5d301f391204792
    347-692-4777
    [email protected]
    ASMHVACNYC.COM
  • JStarJStar Member Posts: 2,668
    Gas
    Were you getting 6.8 in when the valve was open, or only static?
    - Joe Starosielec
    [email protected]
    6.8"wc
    With valve open
    347-692-4777
    [email protected]
    ASMHVACNYC.COM
    Rheem
    Sounds like the valve. I would try to send 24v right to it first. Could also be a low amp draw on the valve circuit, which might lead to a faulty control board.
    - Joe Starosielec
    [email protected]
  • heatpro02920heatpro02920 Member Posts: 991
    Did you
    call Rheem tech support? Sounds like a gas valve, is this a natural draft installation?
  • John MillsJohn Mills Member Posts: 741
    I seem to recall
    hearing of manufacturing oil in the burners block the crossover. Try washing out the burners.
  • unclejohnunclejohn Member Posts: 858
    Is this the set screw
    Adjustment that has a 2mm set screw inside a 3mm set screw? If it is you need to replace the valve and If you ever find the guy that dreamed that up, kick him in the butt.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
