Heat Loss up chimney for water heater
Jfonto
Member Posts: 43
Anyone know what the heat loss for a chimney,with only a hot water heater on it , would be.
I'm think of going to a direct vent unit and block off chimney.
To be specific,
what's the heat loss from the draft drawing out heated air and sucking in cold?0 -
It Depends
Obviously, the colder the outside temperature and/or the higher the water temperature in the heater, the greater the heat loss. A direct fired water heater can lose 8 degrees per hour when really cold. A direct vented water heater will have heat loss as well (maybe not quite as much?) unless there is insulated venting with a damper (which I'm not sure is available or practical).
My thinking without really investigating it is it would not pay to do this.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
