Another thermostat question for one pipe steam system
Dima
Member Posts: 3
Hi All.
This probably will be the millions thermostat question on
this board but I need some help selecting a new thermostat and specifically the
right CPH setting.
I have a two family house (two floors) with a one pipe steam
system. However, instead of cast iron radiators, the system has iron/steel
(black pipe) find tube convectors. I
want to replace the old original Honeywell round thermostat with a digital one.
Almost all of the threads I read here recommend getting a Honeywell Vision pro
series thermostat with adjustable CPH and set it to one cycle per hour. This
setting would probably do well with cast iron radiators, but I am concerned it
might not work well with convectors since they get hot and cold at much faster
rates.
Could anyone please advise on a correct CPH setting
for my system?
Any advice is appreciated.
PS. I read somewhere
( I think on this forum) that select White Rogers thermostats have an option to
select the type of radiators in the system but I can’t seem to find a model
that does it. Did anyone hear about such a feature on their thermostats?
Thank you.
right CPH setting.
rates.
for my system?
Thank you.
Tstat
1, 2, ?
The vision pro allows any number of CPH up to at least 9. Start at 1. If it doesn't work, try 2. It's less scientific than you think.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
