To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
oil boiler and burner info needed
chasechase Member Posts: 8
hello all. need info on a peerless cast iron oil boiler with becket burner. one pipe steam system. cat# ions on wbv-04-150-s ser# 376145-200100. 1.5 gal/hr lt.oil. doe htg capacity or gross output btu/hr 178000 water, 177000 steam. 554 sq ft steam. 133000 btu/hr steam, 155000 btu/hr water. this is the label info. can anyone explain? also, i want to convert to gas. any suggest on a gas burners for this boiler? would it drop the effieciency? any info is appreciated.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
