Heating a partial exposed garage
FitterNik
Member Posts: 1
Is heating a lower level partially exposed garage with radiant a smart way to go. Or would a gas fired modine be a better option? The garage is going to be used as a shop, and I am putting a thin slab above the garage for heating the living space with pex and and NTI condensing boiler. Any ideas or opinions.
Hot dawg LT
I would look at a fan coil designed for low temps.
If you generally keep your slab at a steady temp, and you insulate the garage well, the radiant will work well. If you like to keep it cooler when unused, look at a fan coil.
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
