Snow Melt Water Temps
Wayco Wayne_2
Wayco Wayne_2 Member Posts: 2,479
I have a small snowmelt system for our sidewalk out fron. What sort of water temps should I be seeing across the system, supply and return when it is operating during a snowstorm???
  • Zman
    Zman Member Posts: 7,569
    It depends...
    It really depends on the design. We just did one with 3/4" pex at 9"oc. We used 2" blue board and centered the tubes. It runs really well at about 100-120. I tried it hotter and the heat was uneven. Lower temps also put less thermal stress on the concrete.
    Carl
    Albert Einstein
  • Wayco Wayne_2
    wow!
    I've been running at 90 and was afraid that was too high. I have it set down to 80 as an experiment. I'll let you know how it flys.
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    temp
    90* is the normal design temp for snow melt. Too hot and you will damage the concrete.
  • Zman
    good info
    I may try it a bit lower.
    Albert Einstein
