To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Oil furnace for garage
SidponchoSidponcho Member Posts: 7
I've been looking for a used oil fired hot air furnace for my garage.  I read somewhere that certain furnace don't like being in a cold area like the garage (cold when its not being used)  Should I look for anything in particular?
  • heatpro02920heatpro02920 Member Posts: 991
    used
    is going to make it tough to be choosy with the make and model, I would imagine... I would make sure and check the heat exchanger when you buy...
    What do you need for BTU output? New ones aren't super expensive and come with warranties...
  • icesailoricesailor Member Posts: 7,265
    Garages:
    Be sure to check codes for heights above garage floors. Where I work, it doesn't matter if you park a vehicle in it or not. If the furnace or ignition source is in the same room, codes will apply.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
