Gas light parts
zepfan
Member Posts: 397
Does anyone know where to get parts for gas lights that you would have installed at a house? I have a customer that has one that is about thirty years old, that there is no manufacturer or make on. I am looking to replace the control knob that is broken, if the part or rebuild kit is available.thanks to all.
Gas lights
Can you post a picture of the light, and maybe the valve in question?--NBC0 -
Humphrey...
... is the last maker of gas lights I know of. I'm pretty sure they are still in business.
Yours, Larry0 -
lehmans nonelectric
try Lehmans nonelectric I could be wrong on the spelling.
good luck
M0 -
Re: gas lights etc
Solara lighting still sells some real fancy gas lights. Quite nice. I think I still have some mantles for the old gas lights we use to work on here in Seattle. Basically the same as the old fibrous ones in coleman white gas lights. Pretty simple0 -
found the parts
i was able to find the parts from a company called modern home products,and then bought them locally.they worked perfect.thanks to all0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
