buderus gb312 880
dr.phil
dr.phil Member Posts: 3
ran great for 1 yr. now ithas intermit locking fault 8y/590 reset it and runs great for 2 weeks or locks out one a day technician could not find anything . any ideas thankyou !!!!
  • heatpro02920
    heatpro02920 Member Posts: 991
    edited March 2013
    Codes
    I have seen this before check the vent and intake for blocks. Then make sure your gas pressure is correct was there anything new installed in the gas system... That is a psi switch code.
    That code is either air supply or flu gas pressure. Or it could be high or low gas pressure. That's not the easiest code to t-shoot with out seeing it...
    I have installed about 3 of them units {well the 312 in general not just one size} and they are all still in service, one of which had a problem with ignition but buderus took care of parts and labor...
  • heatpro02920
    edited March 2013
    Codes
  • heatpro02920
    edited March 2013
    Codes
  • heatpro02920
    edited March 2013
    Codes
  • heatpro02920
    edited March 2013
    Codes
