gas pressures
aldevo
Member Posts: 1
Gas valves are usually rated for 1/2 psi max. Why is it trouble often when natural gas is approx. 10" or higher, but hardly ever a problem when lp is approx. 13" w.c.?
nat vs lpg pressures
7" WC is approx 1/4 PSI, I think they make the valves so they can tolerate a lock-up pressure from an upstream regulator of twice the normal working pressure.
I think higher lpg pressures in combination with smaller burner orifices were originally intended to help the venturi effect for an acceptable air/fuel mix on start-up of atmospheric burners.
Not sure what problem you are referring to...Home Owners Please Note:
You are receiving advice from some very skilled pros completely free of charge. One of the reasons I participate is to sharpen my own troubleshooting skills. So; did we get it right? I would be grateful if you extend this courtesy back by posting the final outcome of the issue you are inquiring about. Thanks0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
