Hot water temp low
JJ982
Member Posts: 1
I have an oil fired peerless boiler with tankless coil. Just recently I have had a drop in to water temp in house. The pressure level is fine but temp is waaay to low. The coil was just replaced 1 month ago. The water is very hot coming out of the coil but cools drastically on way to and through coil. As a result ; the hot water temp is cold rather than hot. What could it be
YOUR POST SAYS
"the water is very hot coming out of the coil then cools drastically on the way to and through the coil". can u rephrase your question, i don't fallow?0 -
Mixing Valve?
It sounds like you may have a bad or improperly piped mixing valve. Can you post pictures?
Rob0 -
Cold everywhere...
Mixing valve issue for sure...0
- 85.2K THE MAIN WALL
- 55 Biomass
- 69 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
