To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Circulator Pumps
I recently installed a Nibco Panel purchased from Menards.  It uses a Grundfos circulator pump. I started the system up and let it run for about an hour.  Being a novice to the radiant heat scene I wasn't sure how hot the pump should feel to the touch so I shut the system down and am looking for answers.
Question:  In general  how hot should the pump itself be to the touch when operating?
PS: I do understand that there is hot liquid running through the pump at the time but in general is there a rule the pump should be the temp of the supply from the boiler plus anything or should it not be that hot...
Thank you
  • GordyGordy Member Posts: 6,433
    Depends
    How long it runs, and everyone has a different perception on what feels warm to the touch.
    In general if the system is purged of air, and your sure of that. Then if the circ has been running for a long period of time getting the system up to temp then yes it will get warm to the touch. Not so much you can't leave your hand on it though.
  • SWEISWEI Member Posts: 7,356
    fractional horsepower conventional circulators
    use motors that are only about 50% efficient.  Lots of heat.  An ECM will run quite a bit cooler.
  • AuroraAurora Member Posts: 2
    Thank you
    for your help!
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
