What should the proper fpm velocity be for a furnace in a
ElderGreen
Member Posts: 25
1000 sq foot ranch house? Quite open inside without walls every 5 feet. Only the single bedroom and bathroom are partitioned off. Blower is rated for 1000cfm. Just trying to decide which ducting size for the supply. Then I'll just increase it a bit for the return. Any help is greatly appreciated folks!
thinking 700
does that sound adequate?0 -
At 700fpm
Your at less then .05 SP you should be able to go up to 900 fpm with no real noise.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
