How many strand t-stat wire?
Gee134
Member Posts: 1
I just had my old oil fired hot air furnace replaced with a new oil furnace with an ECM variable speed fan (if that matters). I currently have a 2 strand t-stat wire. He's also coming back to install a heat pump and humidifier. The home has never had a heat pump/central air system or humidifier prior. I'm a low voltage electrician and would prefer running the wire myself. My 2 questions are...How many strand t-stat wire would I need for a duel fuel central air system with a humidifier? (oil warm air furnace with humidifier, heat pump, & ac) He said "probably" 7, but I didn't feel confident of his answer. Second, How would I run the cable for him? Currently my wire runs directly from furnace to t-stat. Would I run 1 t-stat to furnace, 1 from furnace to humidifier on return, and 1 furnace to heat pump? Or 1 continuous run? Thank you for the help. A licensed contractor is doing the installation of the equipment and termination of the wires. I just want to have it in place for him for both cost and time savings.
I like
6 cord thermostat wire. Is there going to be a humidistat up in the house? A/C ?0 -
Conductors
Depending on the t-stat and HP, up to 12. I usually get away with 8
R 24v
C 24v com
AUX/EM
W1 1st stage htg
W2 2nd stage htg
Y1 1st stage cooling
Y2 2nd stage cooling
G fan
O/B reversing valve
S(2 or 3) outdoor sensor0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
