base board heat thermostat
zepfan
Member Posts: 397
does anyone make a line voltage,electric heat thermostat that is digital? most of the ones that i have seen just have a temperature scale or a wamer-cooler scale.thanks to all.
Johnson Controls
Mod A-419. This is somewhat of a stand alone t-stat w/ a remote sensor. Can be used for 24vac or 110vac. Make sure you get the correct one. Appearance is not exactly like a regular t-stat, but offers a wider differential. Note; it's not set back, just a standard type stat. I'm sure someone carries the digital display but the trick is finding one.....
Peace
Mike T.0 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
