Way too hot
radiatorblues
Member Posts: 1
Hi.
I have a steam radiator. It's very old and the valve is so rusted.
They generally kept our building on the cool side and sometimes there was not enough heat. But I always shut it off every night cause I couldn't sleep with heat on.
After turning it on and off many times for the whole winter so far, it started banging like crazy. I got the super to come fix it and I knew that he would tell me not to turn my heat on and off. So he fixed the valve so I can't move it at all.
Now there is more heat than ever....they say it is on a thermostat, but it's soooo hot, I've never had this much heat before. Today it's not even cold out, it's gonna be a high of 60 (yes, in the winter!) and it's blasting. Is every apartment in the building set to the same thermostat? Or could it just be happening to me...
Since I can't turn the heat on or off anymore, what can I do? Is there a way I can do that through the air vent valve on the other side instead? If I block the hole where the steam comes out, will that help?
I also wanted to know if there is a cover I could put on the radiator to subdue the heat...I put bed sheets and then a sleeping bag on top...seems like the sleeping bag is not the right material cause it seemed like it would melt.
using the air vent to control the radiator
with many air vents, they will close when they are turned upside down. try turning as if to tighten it up first, as you do not want to unscrew it acidentally.
sounds like the system is in need of some maintenance. it may be burning twice as much fuel as it should.
can you go over the super's head and notify the management?--nbc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
