To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Glycol in a Snow-Melt System
hwshws Member Posts: 43
I am doing up an estimate to replace the propylene glycol in a snow-melt system at a self-serve car wash. Went there today on a service call and found that the glycol solution had been freezing. What is the typical glycol-to-water concentration for a snowmelt system? I haven't done one before. I've done the typical 50/50 solution in home heating systems...should a snow-melt system have a stronger concentration?? I used to have a chart for this but can't find it now.
Thanks!
  • hot rodhot rod Member Posts: 6,486
    it varies from brand to brand
    and you have three temperatures, 1st when ice crystals form but it is still able to pump, slush point, and burst. How cold do you get in your area?
    Is it a snowmelt outside or de-ice for the bays?
    Make sure you flush the old stuff out well, especially if the ph has dropped way down.
    Recycle the old stuff, often times Quick Lube shops will take it, or Safety Kleen for large quantities. Best not to dump it down the drain, it could be EG.
    Remember to confirm the pump size if you change the percentage to a higher protection level.
    The magic is in hydronics, and hydronics is in me
  • hwshws Member Posts: 43
    edited January 2013
    Thanks HR
    that looks kind of like the chart I used to have. To answer your question, it is a de-icing system for the bays, not a "true" snowmelt. It is worth noting though, that the bays are open on one side and do not have doors of any kind.
    Our coldest recorded winter temp was -9 F, our average cold temp is 11 F.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
