how bad is it really
keyote
Member Posts: 659
Trying to save a bit, doing a reno on my house copper water water system but closed radiant heat and also a pex sprinkler.off the potable i need some temp heat and could save if i used non oxygen barrier left off the sprinkler roll since as i bring each floor onto new system i only need the old boiler to last through this season and maybe one more will it rust that quick?
alternatively i could do the sprinkler system in thermapex rather than aquapex but its not potable rated is it really much different i could use back flow preventive etc but defeats savings
Long term plans
Always subject to change. I would play it safe if your going to use your present boiler for possibly 2 years, or more ya never know. May as well not bury it in oxygenated water along with the other ferrous components in the system. Use the barrior pex.
If its not rated for potable do not use it for potable, not sure how inspectors interpret a sprinkler system in your area. Lawn, or Fire?0 -
thanks
thanks gordy0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
