loud return duct
Paul S_3
Member Posts: 1,261
in Gas Heating
hey everyone i installed a new 100,000 btu 95% warm air furnace new duct work supply and return....everything operates fine, except for the return duct is very loud...furnace is in basement and return duct goes straight up 10 feet to first floor into a return box....it is NOT a AIR FLOW ISSUE, temp rise is fine and if i take the blower door off to allow maxinum air to go through system i still have the noisy return. the noise just sounds like the blower wheel & motor running....is there a way to reduce the noise with running the return duct a certain way or is there such thing as noise reduction ductwork for example if i get ductwork thats insulated inside it??? any help would be greatly appreciated thanks paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Insulate
Replace the return air drop with a larger one lined with accoustic insulation and isolate it from transfering vibration with a fabric duct connector. It works great.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
