Unit (Garage) Heater
Huntrfish
Member Posts: 1
Can I take a 45,000 BTU unit heater and turn it on its side? I would be mounting on a stand about 12 inches of the ground. The access door would then be on the top instead of on the left side as normal.
I have not
ever seen that done before in over 16 years in the field, and I'm sure there is a reason for that. If you have the installation instructions, read them. If you don't have them, go on-line and find them, and then read them. Basically, RTFM ( read the freaking manual). Not the answer you were hoping to hear, I'm sure, but always the best starting point when attempting to do anything out of the norm. Just my thoughts on the matter.0 -
first
you would need to identify the heater before any input can be offered0 -
unit heater
Steam, Hot Water, Gas??????????0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
