aftermath of clogged system
smithwd
Boiler installed after new well installation.......lots of stuff in the water....now 5 years later..
boiler and system flushed but.......
have Taco pumps .. water temp on pump is 146....inlet temp is 91...I also see high temps on some of the tees..4 zone system...91 in..91 out but middle of tee is 146.....
using my infared temp guage to see what's happening.....I also have temp gauge reading 140 when the output is 87 to the zone......
also..on a tile floor within the same zone what should be the max differantial of floor temps?????
My concern is that maybe the system still has deposits left in it from the well...
thanx for any advice......
are you putting
black paint where you are measuring the temps? If not they may not be accurate. Try that first and see if the numbers change.Cost is what you spend , value is what you get.
cell # 413-841-6726
Ditto
On black paint, or masking tape on the pipe. Sounds like erroneous readings to me.
Differential on tile floor should be 10* in a bath, or a kitchen, maybe 15 but delta ts are a guideline, and seldom end up that way. Usually much lower once mrts are are stable,0
- 52 Job Opportunities
