To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
taco zvc405-3 zone control
Billy MarchBilly March Member Posts: 57
replacing wirsbo a3080404 zone control  panel has 4 wire zone valve conn.
has 3 wire thermostat connector  with 4 wire thermostats
tried taco zvc-405-3 but thermostat conn. only have 2 wire conn.
and 4wire zone valve conn is there a taco box or another box that will work
  • Dave HDave H Member Posts: 240
    ZVC thermostat terminals
    You probably have the Wirsbo 4-wire thermostats like the 501. Two of the wires are for 24volt power and two are for the endswitch.
    In order to make this work on the ZVC controller, there should be a terminal on the top left of the ZVC board labeled 24 volt and common. Use this terminal to power up all of the thermostats, and the endswitch wires will go to the corresponding stat location.
    Enjoy
    Dave H.
    Dave H
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
