Gas heater starts and restarts
barrymazada
Member Posts: 1
in Gas Heating
Hello,
I have a 15 year old Bryant gas heater that starts and restarts
The furnace starts sucking in air , the burners turns on, hot air blows out then the burners turn off , hot air seems to continue to blow for about two minutes, I think it turns off because I hear a clicking sound the it starts all over again.
Error code
There should be a window in the blower door that has a lihght behind it.It blinks long and short flashes. Whats the number. If the light is steady on have you installed a humidifer or new tstat recently?0 -
When the blower comes on do the burners remain lit at all while it blows?? Or do they immediately go out, blower finishes it's cycle, then the process repeats??
Also, has anything changed very recently? Such as a newly installed thermostat, or a newly installed humidifier??0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
