whistle
2ndtech
Member Posts: 1
I have a Utica gas boiler, it has been in operation for 12 years. For no apparent reason it started whistling this spring. I have adjusted gas pressures and checked air band settings,adjustested manifold pressure to no avail. It starts out intermittenly then will turn into a constant moan the lomger it runs.it is a utica MGB150 on propane any suggestions??
sounds like
an extrol tank to me?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
