To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
homeowner
I have a 1968 double burner gas central forced air furnace and one burner dose not ignite and the one that does cuts on and off . I replaced the basso switch on the second burner . still does not cut on with new basso and thermocouple I can ignite by crossing the two wire connectors but it will not remain on Any suggestions? ( thermostat is not defective but only one burner cuts on when I turn up the temp on thermostat)
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
