homeowner
bob1
Member Posts: 5
in Gas Heating
I have a 1968 double burner gas central forced air furnace and one burner dose not ignite and the one that does cuts on and off . I replaced the basso switch on the second burner . still does not cut on with new basso and thermocouple I can ignite by crossing the two wire connectors but it will not remain on Any suggestions? ( thermostat is not defective but only one burner cuts on when I turn up the temp on thermostat)
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
