homeowner
bob1
Member Posts: 5
in Gas Heating
I have a 1968 double burner gas central forced air furnace and one burner dose not ignite and the one that does cuts on and off . I replaced the basso switch on the second burner . still does not cut on with new basso and thermocouple I can ignite by crossing the two wire connectors but it will not remain on Any suggestions? ( thermostat is not defective but only one burner cuts on when I turn up the temp on thermostat)
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
