To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Condensing furnace in attic
TonySTonyS Member Posts: 849
Any ideas on piping arrangements or heat tapes on condensing furnaces in freezing attic space?
Now that the 80s are gone, replacements will all be condensing.
  • Jim GodboutJim Godbout Member Posts: 49
    Insulation
    We build a room around them and make sure installs are close to floor system
    Mostly use foam panels very frugal and effective way to protect in unconditioned space if we have to go that route
    Take care
    Jim
    Jim Godbout
  • unclejohnunclejohn Member Posts: 858
    80's are gone?
    I'm putting a 80% in tomarrow.
  • jeremiahjeremiah Member Posts: 8
    condensing furnace
    your best bet is to use heat tape around the collector cup and around the condensate line also insulation like armaflex around the condensate line after the heat tape is on there. also make sure that the furnace is slightly pitched towards the drain outlets of the front of the furnace so that water cant pool up inside the secondary heat exchanger and freeze.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
