Annual Buderus Problem
FB
Member Posts: 45
Just when I'm starting to trust our GB142/24, the house feels cold and the display is flashing 3C/217. Although those codes do not appear in the manual, Buderus tells me it means a communication problem with the fan, the wiring, or the UBA. After resetting, the boiler runs fine for a year or two. Have you had a similar issue with a GB142? Also, there are numerous postings here regarding the need to mix glycol with the circulating water, but the manual is very emphatic that no additives should be used - what do you think? I follow the cleaning procedures in the manual and we're into our seventh year with the only hard failure having been one hot surface ignitor.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
