To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Best steam boiler ?
HeelteeHeeltee Member Posts: 19
could someone recommand one of the best, if not the best steam boiler on the market ?  from 150,000to 200,000,btu, thanks Pros & cons
  • Recipe for best boiler
    The best boiler is one which has been well installed by a competent steam pro. The pro will usually select the boiler from a local stocking distributor. He will determine the size from the combined total of radiation (EDR).
    Generally boiler problems result from bad installation trying to save money for either the installer, or the customer. Unfortunately any cost savings are quickly eaten up by inefficiency, and lost sleep due to water-hammer.
    You will want to discuss with the installer whether to have an atmospheric, or a power burner depending on how soundproof the boiler is.--NBC
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
