one pipe steam using too much propane
Tiny
Member Posts: 3
I have a one pipe steam weil mclain PEG-40 propane boiler that is using an excessive amount of propane, about 130 gallons of propane in two weeks. The weather has not been too cold yet (NE PA) We have electric hot water, so this is strictly for steam. The boiler less than a year old. We have had two techs look at the system and unable to determine the issue. Any suggestions would be helpful.
Thanks,
Tiny
Thanks,
Tiny
Info
Out side of the high fuel use how is the system working? Does it seem to be taking to long to get steam into the radiators, is there are banging in the pipes?
What kind of boiler is it and how many radiators is it feeding?
What kind of Radiator air vents are you using?
What kind of main vents are on the system?
Post some pictures of the boiler from front and back, show the piping around the boiler and any main vents in the cellar.
3PSI gauge0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
