Arco Gravity boiler
steveo1
Member Posts: 8
1906 water boiler converted to natural gas.
My client purchased this home under the assumption boiler worked.
I found it has a water gauge on top left and a small possibly broken temprature gauge on top right.
There is a floor standing expansion tank with no vents that I can find.
The only control other than a heating thermostat and thermocouples on the gas valve.
Shouldn't this have a Aquastat and low water cut off?
What water pressure should we have.
More than likely...
It is a gravity hot water boiler... Low water cutoffs and aquastats are a new invention compared to the age of the boiler. A stack switch was used to control the temperature. A new boiler is prob. the way to go.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
