A GFCI receptacle as a LWCO
bill_105
bill_105 Member Posts: 429
So it's 10 p.m. last night and 13 degrees out. A neighbors house sitter calls and says the heat is out.
The system had glycol and the make up was off. It did not have a LWCO.
What it did have was a leaking boiler drain at the boiler return. As the fluid leaked out the pump ran dry and tripped a GFI the boiler was plugged into.
The pump was ruined but the boiler lives on. What a twist! A major company was there in Sept.
    Steamhead Member Posts: 16,832
    Can't make this stuff up
    this might be a good place for ME's "pig" setup as well as a LWCO.
    Consulting
  • HDE
    HDE Member Posts: 225
    Wet rotor?
    You dont mention what type of circulator but it happens often. The pump windings shorted to ground and tripped the GFCI.
  • HDE
    Wet rotor?
  • HDE
    edited November 2012
    Wet rotor?
    Duplicate post from ipad
