Info on enerroyal furnace
tbrown10
Member Posts: 2
in Oil Heating
Does anyone have any info on an EnerRoyal Furnace Model# ERLB 56-84-SFR? Age? Manual? Parts List? Diagrams. Serial Number is 898820
24 years old
Consider yourself lucky if HX isn't cracked.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Newer then I thought
Wow if you look at the furnace from the outside it looks like it was made in the 50's (Rounded Corners, A heat exchanger clean out port on both sides (Tech told me he had only seen a couple with those), A nice tray for the filter). Maybe that's why the company went out of business.
The Heat X looks great I am told. The issue I am having is the combustion chamber has disintegrated the tech says they make no parts for these furnaces anymore so they are looking for an aftermarket one and the first one they ordered didn't fit correctly so they are ordering a different one. I just want to get a couple more years out of it. Is it worth it?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
