AquaHeat Manifold Question
Edbrown
Member Posts: 8
We have an existing system using these manifolds and now would like to split it into 2 zones. Was hoping to add "Zone Valves" to the top of the existing valves - I have seen similiar things used, but have never installed them.
Any ideas would be great - Its in a tight location, making additional piping tough.
Ed
Ed
manifold
you can put the heat motor actuator on the manifold loops you want to control. you will have to wire the t-stats to bring on the pump / boiler / zone valves. ect.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
