cast iron radiators
do_it_myself
Member Posts: 1
I am installing a cast iron radiator and I am not sure if there is a right or wrong way for the in or out pipes. I have a bottom to bottom set up and just want to know which way to flow the water.
rad connections
The most ideal way to pipe them is in top/out bottom. Bottom in/bottom out will work but depending on the rad you would reduce it's output by 5-10%
If you're wondering about flow direction, it doesn't matter.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
