I've decided I need to change t-stat mfg.
ctjomac
Member Posts: 52
Where I work we have literately hundreds of thermostats controlling single stage residential water source heat pumps. In 1990 at start-up of the facility we had Robertshaw snap acting thermostats. When we started having problems with them ( bi-metal inaccuracy, dirty contacts, etc. ) we began to switch over to the newer Honeywell T8775C1005 Digital Round. They are easy, large enough t see and when the display flips from set point to rom temp. the residents dn't know that it may be a few degrees off :) After a short time they fail at random (very annoying for me) I need a thermostat that is easy to see...easy to operate...accurate ( the bi-metal ones never reflect actual temperature) and will last a god amount of time (is 5 years reasonable?) I deal with the elderly and they need all of the above and I need one that I don't have to change all the time.
Any suggestions for the next type I should try?
stats
is this heat/cool or heating only?
I've used these:http://www.tekmarcontrols.com/products/zoning/537.html
when people can't handle something too complicated, just up & down. They are very reliable too, i've had lots of tekmar thermostats last 15 years.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
