steam pressure switch
Hoffa
Member Posts: 1
On a low pressure residential steam boiler, what would a good choice for a pressure switch? Currently the boiler is 17 years old and only needs to run on about 1psi of steam. The honeywell pa-404b control is set at .5 with a differential of 1. that's the lowest we can set it. Any other control that might work better? Thanks
Pressure
Honeywell Vaporstat L408J1009
Can be set from 0 to 16 ounces.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
