Where to put a CO detector?
KCA_2
Member Posts: 308
Hello...
I heard on the radio today that installing a CO detector low... +- 18" off of the floor, is the best location... My thoughts were that CO comes from a heating source, Boiler or Furnace, and because hot air rises then CO detectors should be high...
What is correct?
KCA
What is correct?
KCA
:-) Ken
where do you breathe?
18" off the floor is good if you're a dog. Otherwise, put it where you breathe--typically btw 24-60" off the floor whether standing or sleeping. Should be within ~15LF of each sleeping room.
For maximum protection, throw out the CO detector and get an unlisted CO monitor0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
