To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Series ECM Blowers
Does anyone know what will happen if you series two air handlers with ECM blowers?
Will they behave or become disoriented?
  • EmpireEmpire Member Posts: 2,343
    TWIN
    If I'm not mistaken, there is a setting to twin the 2 units to act as one.  Check your local manufacturers manual.  Others will chime in to check my opinion.  Make sure there is a common plenum so feed back can affect both units.  My .02
    Mike T.
  • HousedocHousedoc Member Posts: 60
    edited October 2012
    Series
    Empire, Thanks for your reply.
    I do know there are twinning kits for parallel configurations. But I want to push the air from one blower into the inlet of another. So the blowers are in series. It would seem they would act the same way as circulators. But I am not sure.
  • SWEISWEI Member Posts: 7,356
    blowers in series
    Given that these are EC motors, the question is really about controls.
  • TechmanTechman Member Posts: 2,143
    ECM
    I think the motors in series will drive each other crazy
    Seems so
    ECM,
    That seems to be the concesus. Apparently theses motors are slow learners. I've been told they will hunt for their programmed operating point and neither one may hit it because the target is constantly moving. But everyone has said they don't know for sure.
    ECM
    They work off of Back EMF and will not work in series
  • John MillsJohn Mills Member Posts: 745
    Huh?
    Series would be one blowing into the next one. That what you mean?
    Twinning would be 2 units side by side sharing the same ducts. Usually you can do this with a fixed speed ECM like an X13. Doing it with variable speed won't work, they will fight each other. Only exception I know of is the Trane/A-S units with a switch to make them fixed speed.
    Yes
    Yes. Supply air from first ahu dumps into return of second.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
