basement hot water loop
Stan_5
Member Posts: 22
I know hot water will migrate up not down on its own in a hot water loop but how much if any resistance will it add to a circulator that is trying to circulate water from overhead down and back up from three separate 6' sections of fin-tube baseboard? The height from the baseboard to the ceiling is about 7'.
2 pipe?
I assume you have a 2 pipe system? Water in a typical 2 pipe closed system is unaffected by gravity. The additional piping will add some head loss to your system. Is this a separate zone or are you extending an existing?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
