Duct sealing
rwhtg
Member Posts: 34
we recently went through some BPI traning and are educating ourselves on duct sealing and duct testing. does anybody do either of these and if so what guidelines or codes are you following other than IECC
Skilled labor isn’t cheap, cheap labor isn’t skilled.
Duct Sealing/testing
Duct sealing & testing is another service provided by quality contractors. Unfortunately, the need is there, since especially during the housing boom, many corners were cut and ductwork suffered a lot of it. It should be a part of your IAQ offering, along with ventilation, humidification, filtration and zoning. Your local codes are what you should follow, along with IECC. Are you an ACCA member? If you are, they can point you toward best practices. Good luck in your new venture.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
