Infloor PEX tubes at control joints
cgw
Member Posts: 42
In a large commercial reinforced concrete slab on grade, the infloor tubing will be installed on top of the reinforcing. They will be cutting 2" down along the control joints. Do you do anything at these joints with the tubing (other than make sure they are deeper than 2")? Does the slab tend to crack the rest of the way through?
yes.. you need to do more...
Here's something that should help
http://www.wattsradiant.com/support/literature/#/wattsradiant-products-hydronic-radiantpex-radiantpexal/WR_RadiantPEX_Manualsteve0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
