Uponor Tstat to Taco Z Controller
Ibeck
Member Posts: 1
How do I wire a A3030102 Uponor thermostat for heating only to a Taco Zone Controller? controller has multiple leads W C Rh Rc G Y I recall, my A3030101 simply connects white to W and red to Rh, but this doesn't work for the 102. I have a blue lead that is connected to a 24V source in the controller, not sure how to connect the 102. Thanks
T-T
Connect the thermostat leads to T-T on the controller.
http://www.taco-hvac.com/uploads/FileLibrary/100-5.1.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
