commercial indirect water heater
bob eck
Member Posts: 930
looking for a commercial indirect water heater 120 gallon ASME rated unit.
Turbomax makes one....
http://www.thermo2000.com/content/en-US/s2_produits/optimizer.aspx
Bear in mind that this is a REVERSE indirect, and it will cause a non condensing boiler to condense under the right conditions. Obviously not a problem with a condensing boiler ,but definitely needs to be taken into consideration for non condensing appliances.
And they do make an ASME model.
METhere was an error rendering this rich post.
So does Viessmann....
http://www.viessmann.us/en/products/speicher-wassererwaermer/Vitocell-V_300.html0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
