I have heat!
Kestrel
Member Posts: 102
I thought I'd post some pictures of my now-functioning system.
I have to give a big shout-out to the community here - I couldn't have done this without you guys.
We have warm floors, and the whole house is pretty warm, despite no radiators on the second floor, or in the basement, yet.
My original plan - to use the system sensor to control the boiler to keep the water at whatever the reset curve dictated - did not work. I had bridged the T-T, and the boiler kept overheating and locking out. I think it's because the alpha was only powered when the boiler was 'on'. I'm thinking that the alpha should have constant power - and the reset curve should be shallower - so the water is as cool as possible. I'm still experimenting. As I have it now, a t-stat in the living room is controlling a z55 upstream of one of the manifolds - that supplies 6 floor loops and 2 radiators on the main floor (very open space). I have the valve wired to TT, so that when the valve opens, the boiler fires and the boiler pump and the alpha are powered. No more lockouts.
brow pex tubing
A question for you guys.
Withing hours of powering up the system, the pex tubing - interestingly, emanating from the supply manifold - began turning brown/orange. Is this normal? Is this because of copper? Is something amiss?
Two of the pictures above show this - any insights?0 -
Iron
Probably dissolved iron in the water oxidizing and turning orange.
My pex looks similar.
IMO, it is nothing to worry about.
Do you have yur own well water?
Peterr0 -
congrats on the heat...
And thanks for coming back. I remember you poppin on and asking tons of questions, and getting tons of great advice.
I agree with Peter on the pipe color.
Everything looks fine, but sheesh, couldnt the installer cleaned up the tubing at the manifold? He had the entire wall behind the piping to attach some clips.
Enjoy the radiant....keep us posted, or ask more questionssteve0 -
I'm the installer!
Yup, it's still a bit messy. Turns out, the PEX is much easier to wrangle when it's warm!
I'm going to get to stapling it all up to the wall nice and neatly.
I also have to shorten some, etc.
I have to drain part of the system anyway - the boiler has a leak in a factory solder joint - just outside the HX, the supply pipe has a slow drip - Lochinvar is sending a replacement part that I'm going to have to attach, and I'll neaten up the PEX when I have to drain it anyway.0 -
city water
I've got Seattle city water - don't think there's much dissolved iron around here.0 -
Nice work
Its great putting something like that together your self isnt it?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Manifolds
It's OK to turn your manifolds over and let the pex enter from the top side. Your flow gauges will be up side down (not a big issue), but your pex piping will be much neater.
Your copper piping looks real good.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
